Max valve lift 55 331
Started by 57eldoking, April 06, 2015, 11:20:54 AM
57eldoking
Does anyone know the maximum valve lift for a standard 1955 331? Asking for a friend, thanks.
1957 Eldorado Biarritz #906
1957 Eldorado Biarritz #1020 http://bit.ly/1kTvFlM
1957 Eldorado Seville  #1777 http://bit.ly/1T3Uo1c
1995 Fleetwood Brougham  http://bit.ly/20YwJV4
2010 SRX Performance
1946 Chevy 1/2 ton pickup
1957 Buick Caballero Estate Wagon (x2)
1960 Chevy Apache 10 Stepside
1991 Jeep Grand Wagoneer (x2)
1992 Pontiac Trans Sport GT
Henning,
Are you asking what is the valve lift specifications for the motor or what would be the maximum possible before coil bind at the valve?
57eldoking
Making the assumption that you want to change cam shafts, the only safe way to do this would be a physical check with modeling clay.  Pull a head, put say 3/4 inch of cclay where the valve will approach the piston (on top of the piston), re4-assemble (with head gasket),, rotate the engine and see what happens to the clay.  That will tell you what you have now, and give you a starting point for a new cam. OR, I might suggest calling Iskenderian Cams.  They were experts at cams, etc. for those motors and maybe Ed will still have the information around.
57eldoking
Thank you Greg, I'll pass the information along.
J. Gomez
Henning,
The MPL shows the intake and exhaust valves to be the same for 1954-1956. The engine specs for the 1955 and 1956 shows the valve lift to be .411”, attached is the 1956.
Good luck..!
J. Gomez
CLC #23082
