1959 Cadillac Turning lights or maybe they are body side lights
Started by BillR. CLC # 29203, April 23, 2015, 12:36:45 PM
BillR. CLC # 29203
Can someone please advise me if the inside and outside of these lights are to be painted or left raw?
Thanks in advance.
BillR.
Bill Rodwick
CLC # 29203
Crew Member:  '59 Sedan Deville Six Window
Eric DeVirgilis CLC# 8621
Outer housing is raw; reflector (front) should be mirrorlike.
BillR. CLC # 29203
Bill Rodwick
CLC # 29203
BillR. CLC # 29203
I understand leaving the outer side of the housing raw (after I kill the surface rust) but how do I get the reflector front to mirrorlike?
Thanks in advance to all the chime in.
BillR.
Bill Rodwick
CLC # 29203
Grant Owen
Bill, Only the reflector for fog light housings were like a mirror finish , the housing you show is the park light housing these were only plated ( Cad , Zinc ) , the actual housings for both fog & park were plated ( Cad, Zinc ) . Hope this makes sense.
BillR. CLC # 29203
Grant,
Thanks for your input.
So, in a nutshell: Clean 'em up, kill the rust and leave as I found them" ?
Thanks.
BillR.
Bill Rodwick
CLC # 29203
59-in-pieces
Bill,
Here are some pics of turn signal and fog light (if you have them) assemblies.
As grant says, the units are cadmium plated in and out.
The fog units are the same except there is a piece of "reflective" glass suspended behind the fog bulbs.
Have fun,
Steve B.
S. Butcher
BillR. CLC # 29203
Bill Rodwick
CLC # 29203
