1947 Cadillac
Started by yumanian, May 01, 2015, 01:21:18 AM
yumanian
Hello all,
Found a 47 61 series
Primer still on and all interior ripped out.
90 percent of the parts are all there .  No holes in the floor board or trunk. I had it running for 15 minutes yesterday.
Took it out around the block sitting on a bucket to drive it.
Was around the block and she just shut off , no noises nothing.
When in tow , i had it in Neutral("p" ) and i could hear the motor turning but no spark
All for now, I have a 1.5 amp trickle charge on it for tonight.
Get back on it in the morning.
My buddy mentioned I might want to investigate inside the distributor for 12v points
I changed the lower and upper water hoses today.
Boy were they rough and a bit of corrosion (pipes) they went on
Thanks folks for comments and its my first time commenting on here
Joe
Smedly
Congratulations on your wonderful find. there is a large wealth of knowledge here that you can tap into along your journey. Please post some pictures, we all love to see lots of pictures. Let us see what you have, let us know what your intentions are and please keep us posted on your progress.
Sheldon Hay
Quote from: yumanian on May 01, 2015, 01:21:18 AM
Hello all,
y.
Joe
If its original it will be 6 volts. Did you drive it on a 12 volt battery? That will burn something out if you did.
gary griffin
#3
 It has been a long time since I have seen a 6 volt trickle charger and now fewer large chargers have a 6 volt component.  Has the car been converted to 12 volt. If not is the battery 12 volt.   If that is the case you have cooked something.  I would put in a 6 volt battery and then start checking things out.
Gary Griffin
Jeff Rosansky CLC #28373
Jeff Rosansky
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
Smedly
Other than the gauges and radio what would the 12 volts fry. I have ran mine with a 12 volt battery since I bought it with no issues, My gen already was no good so I put an alt. on it but it runs fine?
Sheldon Hay
yumanian
Thanks everyone
I'll work on pics for sure.
I do have a 6 volt battery,  brand new one.
I also have a brand new rebuilt carter carb, brand new 8 mm spark wires , new Dist cap , rotor.
Points are new and set at 15 , had them as wide as 25 but the match book trick didn't work.
My friend and I are thinking to pull the Distrib next but maybe not.
This is the fun though , right?
tonight we towed it home again same thing. Goes through the passing gears , turn the corner on our test route and poof , cuts out .
Similar , almost exactly like running out of gas .
Oh , yes a new electric fuel pump. Someone suggested a 8 volt
We bypassed the mechanical one , we like the glass bowl on it lol
anyway, thanks folks
Have fun
I know I am
Love the project , wished my lady did. Lol
Joe
Thanks again , I'll try a pic now, then show some pics from the first day I picked it up . All the trash inside and torn up upholstery
yumanian
Hello
Brand new wiring harness, but there are a couple wires that aren't or didn't come with the harness, that are questionable.
Not many wires , say 2 or three
I'm under the dash now . I have all the chrome off the dash ready to go to paint . I can really get a good look now.
I have my test light checking underneath, next I'll go check the
voltage regulator
I check the juice to the coil last night was good and to the distributor
Then I'm going to recheck the point setting , it dies under driving conditions , never in park idlING
Stay tune
Confused
Points are at 015 , tried 025 book says 12 to 17 on the top of the Distrib  cam (clockwise)
Joe
Bill Gauch #23121
"Similar , almost exactly like running out of gas ."
I would bet that is your answer. You either are running out of gas because you have almost no gas and the sending unit is reporting the wrong level. You come around a corner and the car dies because the small amount of fuel sloshes to the side. Alternately, there is so much crud built up in the tank that there is less gas in there than you think. Option 3 is that the electric fuel pump is pumping too much or too little pressure and you either flood it or stall it when you turn a corner and load it on acceleration. Another possibility is that you mounted the fuel pump with a longer section of soft line between the tank and the pump. You press the gas creating a small surge which creates a vacuum on the soft line, collapsing it and starving it out. If the car won't restart after it stalls but it will restart a while later, the most likely of these scenarios is that you're flooding it out.
Bill
WANTED: Nothing right now.
- 1938 Series 65 - 4-door sedan - Restoration (slowly) ongoing
http://38caddy.blogspot.com/
