29-31 rear tail light i.d.
Started by Duncan Fox, May 04, 2015, 05:46:43 PM
Duncan Fox
Can any of you early car folks tell me the differences if any between the round style tailamps used in the 29-31 V8 and 12 cars? Are the red lens the same size ? To me, they appear to be larger on the later cars.  I am looking for two restorable '30 units  or the larger lens type if any one can help.
1930 V16 roadster
2005 CTSV
m-mman
The authenticty manual says that 1928-29 are identical.
The 1930-31 (353, 355a, 370A) look the same but the 'ball' is smaller and the red lens is closer to the white side lens.  The 'retaining rings' for the red and white lenses are nearly touching.
On the 28-9 there is a half inch(?) between them.
I cant tell if the lens is bigger or if the housing is smaller.
1929 341B Town Sedan
1971 Miller-Meteor Lifeliner ambulance
Other non-Cadillac cars
Near Los Angeles, California
CLC #29634
Duncan Fox
Thanks for answering m-mman, I thought they looked different,but I hadn't considered that the ball might be smaller though. I thought I had better check before trying to source any.
1930 V16 roadster
2005 CTSV
m-mman
BTW if you have not yet purchased the CLC authenticty manual for your car do so!
Information on these early cars is scarce and the manual is an excellent source.
CLC #29634
