59 cad package tray
Started by grandads59, May 05, 2015, 11:11:56 PM
grandads59
Redoing the interior.   What is the base material for the package tray? The area under the window,  behind the rear seat.  Ply'wd, fiberboard etc.
Jon hartwell
Blade
Jon: on my sedan I had some sort of a hard, thick cardboard (I know ... right?) as base which was covered with fabric mesh. I think I saved some samples of both, if I did I'll take some pictures.
Jeff Wilk
USA Aut Parts Supply has the full unit which fits great. The fabric top though is close but not original. SMS has oem material. So I got both and covered the USA sub material with the SMS oem fabric
Southern New Jersey
SOLD
1958 Cadillac Sixty-Special
1958 Cadillac Sedan
1958 Cadillac Coupe Deville
David Greenburg
For my '60, I did something similar, only bought my shelf from OPGI,which might use the aame supplier. On my car, someone had mounted what appeared to be correct material on a  thin white melamine board, which looked weird and was noisy.
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
Blade
Jon: here you go, I found the pieces I saved from the paper base that was underneath the fabric mesh, it's a thin but hard pressed paper that was glued to the metal and the fabric (see my previous picture) was covering it. I took a picture of both sides for you ... hope this helps.
