How To Load Test An Ignition Coil
Started by Jon S, May 13, 2015, 01:06:58 PM
Jon S
How do you load test an ignition coil to see if it's breaking down under load or heat?
I'm thinking this may be causing the stalling at stop sighs problem on hot engine . . .
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
walt chomosh #23510
Jon,
  GM had a machine that heated the coil for proper check. The simpliest method for troubleshooting would be to install another one and test.(don't stray too far from home!) Coils can be a pain....I've had my share of failures,thus,I carry a spare....walt...tulsa,ok
Jon S
Quote from: walt chomosh #23510 on May 13, 2015, 05:40:19 PM
Jon,
I bought a new one, but these "replacement" parts are 2 1/4" wide as opposed to the 2 1/8" width of my original coil and do not fit into the coil holder for a test drive despite buying a longer screw, etc..  It goes back to the nobody can make replacement parts correctly.
Jon
1981 Corvette
2004 Mustang GT
