50 4door wiring problems with column
Started by reds, May 18, 2015, 12:17:13 PM
reds
I have 2 sets of 3 wires and a lone black wire.the car was gutted and I dont have and info on what wire does what in the column.my new harness says nothing.I called the manufacture back and it was like talking to a wall. Guys im new and could really use the help.if I can find what wire in the column is the ignition flasher feed and the turn signal feed and the brake light switch wire I can get it the rest of the way thanks very much
wrench
I have a 51, so not sure how relevant this is...
Black wire is horn.
The flasher feed may be natural with red and black cross tracer.
The stop light switch feed  may be natural with red cross tracer.
Front left TS   = natural with black tracer
Front right TS = natural with red tracer
RR TS            = green with yellow
LR TS            = green
That is what it is on my schematic for the 51.
Good luck
1951 Series 62 Sedan
1969 Eldorado
1958 Apache 3/4 ton 4x4
2005 F250
2014 FLHP
2014 SRX
reds
Oh man you are awesome!  Thankyou so so much.I hope I can finish it up in the morning. This site is great!!
reds
Quote from: wrench on May 18, 2015, 01:22:39 PM
Black wire is horn.
LR TS            = green
Good luck
You are the man!!! I just wired it up everything works perfect! 5stars great info
wrench
1969 Eldorado
2005 F250
2014 FLHP
2014 SRX
