If you look up the AC delco rear caliper on Rock Auto it lists it as 79-85 Riviera, Toronado,
Eldorado and 80-85 Seville.
I sort of recall when I got them for my 80 Eldo it didn't list them as fitting that car either but
they did. The reason those calipers are made new is they are used for rear disc conversions.
My 81 Riv has drums and they just work. Braking performance does not really seem any
different than the Eldo that had rear disc. Apparently for the Riv and Toro rear disc was
an option. Eldo Seville it was standard 76 on.
I knew 79 Toro had rear discs an an option (having owned one of each), suspected the
same for Riv. But you are saying they continued to be an option for the 7 years, that
multiplies my chance of finding a drum setup by 7
After the discussion I am suspecting an answer to my Eldo rear lockup problem. I had
to add a proportioning valve to the rears and crank it nearly to the limit, to make the car
safe in slippery weather. The disc brake pads available come in organic (very sensitive
but sensitive to heat) and harder stuff (ceramic or semi-metallic, need more pressure but
tolerate more heat). If my car somehow got ceramic in front and organic in the rear, it
would be a lot more prone to rear lockup, and it didn't help that my rear tires were a size
smaller. Perhaps if I tried organic in front & ceramic in the rear, things would be a lot
better. Also have 4 (new) tires all the same now.
I prefer to have large brakes to begin with, and use the low performance organic elements,
which don't gouge out my rotors/drums nearly as much. Changing them more often is no
big deal when you do your own. Not into needing huge brake capacity here. Bruce Roe
