1959 center driveshaft bearing and housing
Started by john shippan, June 18, 2015, 10:44:20 AM
john shippan
Hi all, I have a 1959 model 62 and its time to replace the center drive shaft bearing and vulcanized bracket.
I have seen replacement units available from a few vendors and was wondering if anyone has used these as opposed to having the original re vulcanized and replace the bearing.
It seems that the replacement part will be faster and less expensive but as we all know that is not always the best choice.
If anyone has been down this road before I would appreciate any input.
Thank You John Shippan
