Running board rubber
Started by MitchHodge, June 20, 2015, 07:36:35 AM
MitchHodge
I have noticed that Steele is selling many running board matting except for Cadillac's / LaSalle's?
Does anyone know of anyone selling a good match to running board rubber for a 1940 LaSalle Coupe?
Not an easy task with the molding of rubber around the front and rear of board as well as the two inch piece that come's up from the board along the body of the car, that was done originally by Cadillac
Thanks for any feed back
Tom Boehm
Hello Mitch, Nobody sells a glue on mat for 1940 Lasalle. Your only options are expensive but high quality. There are two separate companies in Canada that will custom recover your runningboards. www.runninboardrubber.com, and www.runningboardrubbermats.com.
