Author Topic: Convertible Top Frame '60 Eldorado  (Read 1267 times)
Offline Whit
  • Name: Whit McFarlin
« on: July 28, 2015, 04:06:04 PM »
Rebuilding the frame of the convertible top on my '60 Eldorado. The chrome plated sections need re-plating and the joints could use new bushings (they are nylon). I had to grind off the staked pins to get the assembly apart, now I can't find where to get new pins and bushings.
Does anyone out there know a source for these kind of parts? Is there a re-builder out there that might have some parts or might help out?
thanks   Whit
Offline 76eldo
  • CLC Number: 22443
  • Name: Brian Rachlin
Re: Convertible Top Frame '60 Eldorado
« Reply #1 on: July 28, 2015, 06:06:51 PM »
Whit,
Google Penn Dutch restorations in Glen Rock, pa.
He just did a 59 and probably knows.
Ask for Jeff or Devon and tell them I told you to call.
CLC # 22443
Offline Whit
« Reply #2 on: July 28, 2015, 09:07:40 PM »
Thanks Brian...will do.   Whit
Offline n2caddies
  • CLC Number: 26143
  • Name: Randy George
Randy George CLC# 26143
1959 Series 62 Convertible
1960 Series 62 Convertible
1964 Deville Convertible
2015 SRX
Offline 76eldo
  • CLC Number: 22443
« Reply #4 on: July 29, 2015, 08:06:46 PM »
Nice!  If that everything you will need there's your answer!
CLC # 22443
Offline Scot Minesinger
« Reply #5 on: July 29, 2015, 09:17:58 PM »
USA Parts sells them.  I bought a set of bushings and bolts for my 1970 Cadillac and it was just over $200.  I went on line and the place selling them has same prices as USA Parts.  It is from a shop in CA that makes them.  The 59 and 60 look like they are $299.  The kit they sent me was top rate, with detailed instructions brass bushings to replace the nylon ones, and super quality hardware.  I was a little worried because the directions show the frame off the car and in sections on the workbench.  Like a dummy I had just replaced my white convertible top.  However, I was able to do the job with top on and it took about four hours a side going slow and carefully.  After the top went up and down smoother and no rattles.
Offline n2caddies
  • CLC Number: 26143
« Reply #6 on: August 01, 2015, 06:52:33 PM »
What is the name of the vendor in California?
Randy
2015 SRX
