1954 Series 60 Trunk mat
Started by 1954 Fleetwood Series 60 Special, July 31, 2015, 05:51:13 PM
Barry M Wheeler #2189
They should as they share the same body shell.
Barry M. Wheeler #2189
1981 Cadillac Seville
1991 Cadillac Seville
Thank you. I thought that but just thought I would check.
Cheers
Ralph Messina CLC 4937
You should check the listing again. It says 62 Series which has a smaller trunk that a 60 Series. If they offer a 56 60 Series it should fit. I believe this one will be a little small.
2018 GMC Yukon
Thank you. I wasn't aware of that.
kkarrer
Yes, there's a difference between the series 62 sedan and just about all of the others as the series 62 has a shorter trunk.  I'll have to check, but there may be some differences between the convertible and the sedans as well, but if you're dealing with a coupe or a fleetwood they should be the same from 54 to 56.
Ken Karrer
CenTex Regional Dir.
1955 convertible coupe
