1958 Radiator Size?
Started by Cadillac Nut, August 15, 2015, 11:54:46 AM
Cadillac Nut
Hi,
Can anyone get me the measurements and perhaps a few photos of a '58 radiator?  I need to make sure mine is correct.
Garrett
wbdeford
1958 Sedan de Ville
Past:
1956 Fleetwood 75 Sedan
1957 Fleetwood 60 Special
1960 Coupe de Ville
1966 De Ville Convertible
1970 De Ville Convertible
1971 Eldorado Convertible
1979 Sedan de Ville
1980 Seville
Cadillac Nut
Will try to do that tomorrow.
wbdeford
1958 Sedan de Ville
Past:
1960 Coupe de Ville
1979 Sedan de Ville
1980 Seville
willits
Here are a few photos of mine when it was out.
Peter
Peter Willits
1958 Coupe DeVille http://bit.ly/1O6BGVu
1961 62 Convertible http://bit.ly/1O6BHst
2008 STS-V http://bit.ly/1O6CI3P
Cadillac Nut
Thanks for the photos.  I have no idea how I missed this before, but I noticed that my radiator is for a '57!  I have a '58 Fleetwood w/ A/C  Supposedly you can modify '57 radiators to fit '58.   I believe the difference is in the outlets.  Anyone ever done that before?  Here are some photos of mine.
Cadillac Nut
2 pics
I believe that your radiator is for a '58 model, but built in 1957. If you loor at the Willits pictures, the lower outlet is at the same location. On a 1957 car, the outlet is on the passenger side.
Alain RIAZUELO
Hi,
The 1957 is the only year to have the lower radiator hose on the passenger side . The water pump is not the same as 1958 (lower inlet )  and the front crossmenber frame have a stamped form on the right side to fit the hose curve. The 1958 model is the opposite.
As Roger Zimmerman say, your radiator fit 1958 year yet it's stamped 1957.
Alain RIAZUELO.
1957 Coupe de Ville
1974 Pontiac Formula 455
1974 MGB GT V8 215
Walter Youshock
That's for '58.  1958 was the first year for the transmission cooler in the radiator.  I also see the drain is on the outside of the tank.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Cadillac Nut
Thanks guys.  So I have the correct radiator, that's good.  I'm having trouble getting it to fit in though which is why I originally thought it was incorrect.  Doesn't seem to want to fit in under the cradle.    Anyone have any thoughts?  From what I recall seeing, '58 radiators had the lower outlet bent up more but my memory could be bad.  Thanks again.
Garrett
