For your reference, the 1981-89 RWD Fleetwoods and Broughams use the same module. The Eldo/Seville are 80-81, and 82-85. They are getting tough to find. Typically the compressor turn on circuit goes bad and/or the fan stays running.
When you do find one replace your blower motor. As these motors age, they will pull more current and can contribute to the module failing sooner. Since blower motors are fairly cheap, it worth the added protection.
Tim
