lasalle hood bumpers
Started by camelot, September 08, 2015, 06:04:55 PM
camelot
I'm wondering if anyone with a 39-40 Lasalle has any rubber cushions or pads where the hood meets the fender or sides for the hood. I looked for holes where maybe there might have been some rubber cushions but don't see any. The only cushioning material I see is on the cowl? The parts book isn't too clear on the late 30's cars when it comes to pictures. Yes the page is blank! Can't believe they let it be metal to metal when closed.
1939 Cadillac 7519
1940 Lasalle 5019
1962 Cadillac 6339 4w
Barry M Wheeler #2189
No, they would not have had metal to metal. On page 98 of the Cadillac Master Parts book reprinted by Faxon Auto Literature, it shows a large drawing of the hood/grill area. There are arrows pointing to what they call "bumpers" which would likely be made of rubber to cushion the hood. These are most likely available from Steele Rubber or Metro Molded Parts. You should have small holes on the top of your grill shroud where these bumpers would have gone originally. Many times these small rubber parts get old and hard and simply fall out. Some previous owner may have started to clean/paint the shroud and taken them out. In any case, that's where they go. Good luck.
Barry M. Wheeler #2189
1981 Cadillac Seville
1991 Cadillac Seville
tturley
I have a 40 Lasalle and it has four bumpers that are attached with the screws that holds the triangular sheet metal piece on. I got new ones from Steele.
Member # 28929
1940 Lasalle model 5019
1995 Ford F-150
2015 Buick Enclave
camelot
Thanks guys. I will go back and check the books again.  I have the faxon books, but didn't notice the bumpers. My books show the split hood yrs. I have a blank page where I would expect the late 30's hoods.
1939 Cadillac 7519
1940 Lasalle 5019
JoeCeretti
1938 60S nearly done and then destroyed by fire :(
1989 Buick Riviera (Arctic White Paint / Blue Cloth Interior)
camelot
Thanks Joe, Saw those couldn't pick the correct one without knowing what they look like. My triangular plate has all new screws in it. Phillips to be exact. So not sure what goes there. Also I have the master body parts list book 35-40 and the chassis parts list book 35-40 neither of which show grille area or hoods except for the 2 piece version. That's why I'm stuck. Whats correct? group 13 of the chassis book is the hood section, pg 474 &478 are blank. I figure those are the pages that should have had it. Group 6 cooling is as close as I can see. it shows a few group 13 parts .
1939 Cadillac 7519
1940 Lasalle 5019
Brad Ipsen CLC #737
Don't know if 50 series is the same but on the 52 series the triangular panel has square rubber pads (the first part in the Steele link for $16 ea.) in each of 4 screws.  The screws are supposed to be slotted pan head #10-24.  Again this is 52 series so not sure on 50 series.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
tturley
Member # 28929
1995 Ford F-150
2015 Buick Enclave
camelot
Ok guys thanks .Then that's what I'll put on. I'm just  trying to keep it as original as I can.
1939 Cadillac 7519
1940 Lasalle 5019
