G'day Mark,
Is the car LHD or converted to RHD?
Firstly, the gear indicator is not connected to the ignition system, but is just an indicator needle that shows the gear position when it is correctly adjusted.
The Neutral Start-safety Switch is actuated by the gear shift shaft that goes down inside the steering column. This NSS is also the Reversing Light switch, and the Auto Park Brake Release, which is Vacuum operated.
Now, could it be possible that the indicator has fallen off and managed to short out some wiring that affects the Starting circuit?
Next, does the Reversing Lights come on when moving the gear lever? And did the Park Brake release when going out of Park, with the engine running before this current problem?
Bruce.
