How to adjust shift indicator needle on a 1957 Cadillac
Started by Cadillac Jack 82, September 10, 2015, 10:02:54 AM
Cadillac Jack 82
My shift indicator is off as it reads between P and D when its in Park and nearly disappears when I put it in Reverse.  Is this an easy adjustment or do I have to pull dash components off in order to correct this?
CLC Member #30850
1959 Cadillac CDV "Shelley"
1964 Cadillac SDV "Rosalie"
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1955 Packard Clipper
1957 Cadillac Series 62
1962 VW Bug
1962 Dodge 880
1966 Mercury Montclair
1968 Chevy Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln MKV
marty55cdv
  There is a plate that comes off the bottom of the steering Column, it is held on with a couple of decorative screws, the pointer mounts in that area behind it and you can adjust it there.
Marty Smith
  CLC #22760
41 60 Special http://bit.ly/1Wm0GvT
55 CDV http://bit.ly/1G933IY
56 Fleetwood
1958 Extended Deck http://bit.ly/1NPYhGC
1959 Fleetwood  http://bit.ly/1OFsrOE
1960 Series 62 Coupe
1960 Sedan DeVille  4 window Flattop
63 Fleetwood http://bit.ly/1iSz17J
1964 Eldorado http://bit.ly/1Wm17GA  (Living in California now)
1988 EBC http://bit.ly/1iSACKz
Jon S
Quote from: marty55cdv on September 10, 2015, 01:11:46 PM
It is held on with a small nut/screw and has fore/aft left/right adjustment.  It can fall in your hand if you loosen it too much and be careful not to mess up the red paint as you adjust it because it can rub on surrounding areas.  Ask me how I know.
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
cadparts58
Tim,
  If you take the lower cover off the steering column you should see where the indicator is attached to the column. There is one screw that holds it in and can be adjusted by loosening the screw and moving the indicator up or down. It has an elongated hole for adjustment. If the original screws are on the cover they can be a bear to loosen. They almost look like reverse torx head screws, but are not. You may be able to get them loose with pliers. They are the only screws on the car that are made that way. Hope this helps. Frank
Frank Puma #10721
Cadillac Jack 82
Okay that seems really easy to do.  I'll give it a try over the weekend.  Thanks!
CLC Member #30850
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1977 Lincoln MKV
markcoombs
Hi all the gear position indicator has fallen off on my 1960 cadillac and it no longer starts wondering if the two are connected and if anyone can provide advice on how to reinstall thanks
G'day Mark,
Is the car LHD or converted to RHD?
Firstly, the gear indicator is not connected to the ignition system, but is just an indicator needle that shows the gear position when it is correctly adjusted.
The Neutral Start-safety Switch is actuated by the gear shift shaft that goes down inside the steering column.   This NSS is also the Reversing Light switch, and the Auto Park Brake Release, which is Vacuum operated.
Now, could it be possible that the indicator has fallen off and managed to short out some wiring that affects the Starting circuit?
Next, does the Reversing Lights come on when moving the gear lever?   And did the Park Brake release when going out of Park, with the engine running before this current problem?
Cadillac Jack 82
Should be an easy fix.  On my 57 it was attached by a small bracket and bolt screw.  Mine was loose and I was able to adjust it properly.  Its amazing how easy these cars are to fix/work on.
CLC Member #30850
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1977 Lincoln MKV
markcoombs
Thanks All appreciate your advice my car is LHD Bruce great to hear its not connected to ignition system will check out the starting circuit and reverse lights and get back to you
