Weak power antenna in a 1957 Caddy
Started by Cadillac Jack 82, September 12, 2015, 11:27:35 AM
Cadillac Jack 82
So my antenna works...but its slow and sluggish.  Does it need some greasing up or is the motor going south?
Tim
CLC Member #30850
1959 Cadillac CDV "Shelley"
1964 Cadillac SDV "Rosalie"
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1955 Packard Clipper
1957 Cadillac Series 62
1962 VW Bug
1962 Dodge 880
1966 Mercury Montclair
1968 Chevy Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln MKV
Jon S
Quote from: 57shark82 on September 12, 2015, 11:27:35 AM
I've never lubricated them other than wiping light oil on the extended shafts and wiping it off after two up and downs.
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
cadillac ken
my experience with the power antennas and power windows is that the sluggish operation is usually as you guessed, the motor "going south"
But with that said, I would still remove it and disassemble to inspect it.
Glen
My experience is not the motor going bad but the grease in the gears getting old.  Take it apart and clean out the old grease and put in new grease.  You will be surprised what a difference it makes.
Glen Houlton CLC #727
CLCMRC benefactor #104
TonyZappone #2624
Use silicone rather than oil or grease.  The oil accumulates in the gear and reel area and messes everything up.  400 steel wool with silicon and a rag will usually speed things up.
Tony Zappone, #2624
1936 Pierce-Arrow conv sed
1947 Cadillac Conv cpe
1958 Cadillac conv
2016 Cadillac CT6 Platinum
