Hard to make a judgement with the info you've supplied. If the engine runs well, has good oil pressure, appropriate internal engine temperature (no hot spots), and good compression (leak down test), the next step I'd recommend is an engine oil analysis to check for metals in suspension. May be someone on the blog knows if these parts will cause engine failure, but if the engine is running well, and it passes these tests, you may be fine. I did purchase a rebuilt marine engine that had a serious mismatch in the valve train. It ran well, but had an audible and annoying valve train tap--the owner spent a ton of money but sold it to me for a "song" ... after 600 hours of run time, the valves burned... (wrong sized push rod and tappets) -- if the price is good and the rest of the car is attractive, hell, go for it (IMHO) Happy day, James
