Your speedo needle has 2 bearings, one in front. The other is in back, right in the center of
the rotating magnet assembly the cable drives. If that bearing gets dry enough, it can try to
grab the needle and throw it higher. Unfortunately adding lube means taking the speedo
completely apart. Bruce Roe
