1968 DeVille fuel lines
Started by Matt 12861, September 19, 2015, 07:16:27 PM
Matt 12861
Has any one ever got the front to back fuel line and return lines off in one piece?  is it possible or should I give up now.  The car isn't on a lift but it is sitting about two feet off the ground.  And what about the clip that holds the lines above the coil spring?  I think someone before me rounded the head, but it feels like even if I get it unscrewed it would barely clear the body.  Any ideas?  Thanks,
Matt Givler
Matt Givler #12861
There is no point.  Presuming you are replacing them.  It should not matter if they do not survive removal.
The fuel lines front to back have been replaced on all three of my 1970 Cadillacs.  To get the pre-bent replacements installed in one piece you have to remove the passenger side body bushing over the rear axel, which is quite a task unless you plan to replace the body to frame bushings - yes did that too.  If you don't want to remove the bushings, you will need to cut and double flare the fuel lines with splices in at least one place.
Must be a real nice mechanical restore you are doing, as few of my friends go this far.
Enjoy your Cadillac!
