All Cads
Author Topic: 1957 Cadillac issues  (Read 1233 times)
Offline 55 CDV Fan 82
  • CLC Number: 30850
  • Name: Tim Neumann
« on: September 25, 2015, 11:28:38 PM »
Okay...so as many of you know I just started enjoying my 57.  It runs great but there are a few minor issues (all of which I'm sure can be easily remedied).  My wiper blades work...but of course they stop when I'm accelerating.  I can only get them to activate when I let off the gas.  Is there a factory or correct aftermarket vacuum reservoir that I can use or should I check my lines?  Also my brake lights have a tendency to stay on sometimes unless I pull up slightly on the brake pedal.  Is this cause for an adjustment or is something else up?  Overall I love this car....quiet...fast...smooth.  I can understand why Cadillac is superior!
Tim
CLC Member #30850
1955 Cadillac Coupe Deville "Evelyn"
1967 Buick Wildcat Convertible "Joyce"
Past Cars
1937 LaSalle Opera Coupe "Adeline"
1940 Chevrolet Coupe "Scarlett"
1941 Ford 11Y truck
1954 Buick Special 48D
1955 Packard Clipper Super Panama
1957 Cadillac Series 62 Coupe
1962 VW Bug
1962 Dodge 880
1966 Mercury Montclair
1968 Chevrolet Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln
  • CLC Number: 30850
  • Name: Tim Neumann
Re: 1957 Cadillac issues
« Reply #1 on: September 25, 2015, 11:29:28 PM »
Going back to the wiper blades they have a tendency of slapping against the bottom windshield trim.  Can this be adjusted so it doesn't do this or is this common?
Tim
CLC Member #30850
Past Cars
1941 Ford 11Y truck
1962 VW Bug
1962 Dodge 880
1977 Lincoln
Offline Glen
  • CLC Number: 727
  • Name: Glen Houlton
« Reply #2 on: September 26, 2015, 12:19:40 AM »
I’m not an expert on this but I remember there was a post on here a couple of years ago about the vacuum tee on the firewall that is actually a pair of check valves.  The car has (or should have) a vacuum pump that provides vacuum when manifold vacuum is low.  The check valves provide the switching between the manifold and the vacuum pump.
If the wiper motor is worn it may make the problem worse.
The slapping maybe caused by worn linkage points.
Glen Houlton CLC #727
CLCMRC benefactor #104
Offline Roger Zimmermann
  • Switzerland
  • CLC Number: 21015
  • Name: Roger Zimmermann
« Reply #3 on: September 26, 2015, 03:35:21 AM »
The slapping from the blades may be the result of the wiper arms installed incorrectly or also because the cables have an insufficient tension. Look at the shop manual how to restore the tension, which is easy: rake away the wiper arm and push on the shaft.
I'm th one who wrote the story of the vacuum manifold at the firewall. After almost 60 years, the rubber valves are hard like rock and don't work anymore.
Offline Walter Youshock
« Reply #4 on: September 26, 2015, 06:24:08 AM »
Wiper arms need to be adjusted and tensioned.  Have the wiper motor rebuilt if it hasn't been done.  You don't want to get caught in a deluge.
Brake light switch could be failing which is common on '57's.  Have you done any brake work on the car?
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Offline David King (kz78hy)
  • Check out the Eldorado Brougham Chapter
  • CLC Number: 22014
  • Name: David King
« Reply #5 on: September 26, 2015, 06:19:01 PM »
I have the new rubber seals for the check valve.  I was thinking about rebuilding the manifolds/check valves as I have a few cores.
David
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
Offline 54 caddy larry
  • Name: larry mandell
« Reply #6 on: September 26, 2015, 06:39:47 PM »
David
Are the seals for the check valves for sale anywhere?
Larry
Larry M
1954 series 62 coupe
1974 Harley Davidson FLH
My caddy is my never ending work in progress.
  • CLC Number: 30850
  • Name: Tim Neumann
« Reply #7 on: September 26, 2015, 07:03:00 PM »
Found out that the wiper blade is too long and it gets stuck on the window trim.  I checked my vacuum lines and found one that was not fully connected.  The wipers work as they should.  Managed to pull my first 🏆 too at a local car show
« Last Edit: September 26, 2015, 08:46:59 PM by 57shark82 »
Tim
CLC Member #30850
Past Cars
1941 Ford 11Y truck
1962 VW Bug
1962 Dodge 880
1977 Lincoln
  • CLC Number: 30850
  • Name: Tim Neumann
« Reply #8 on: September 26, 2015, 08:50:10 PM »
Not bad for a first weekend out!
Tim
CLC Member #30850
Past Cars
1941 Ford 11Y truck
1962 VW Bug
1962 Dodge 880
1977 Lincoln
Offline 35-709
  • CLC Number: 4719
  • Name: G. Newcombe
« Reply #9 on: September 26, 2015, 10:07:17 PM »
Congratulations!
