Adjusting vent window alignment 1957 Cadillac
Started by Cadillac Jack 82, October 09, 2015, 08:59:48 AM
Cadillac Jack 82
Okay so I know I'll have to pull the door panel off but which bolt adjusts the horizontal position of the vent window?  Mine is off as the upper tip of the vent window doesnt seal with the window frame.
Tim
CLC Member #30850
1959 Cadillac CDV "Shelley"
1964 Cadillac SDV "Rosalie"
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1955 Packard Clipper
1957 Cadillac Series 62
1962 VW Bug
1962 Dodge 880
1966 Mercury Montclair
1968 Chevy Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln MKV
Walter Youshock
Loosen all 3.  You may have to install washers between the door and the frame in different bolt locations until it all lines up.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Cadillac Jack 82
Damn I was hoping it was a simple adjustment.  Not too big of a deal...just more of a pain in the a$$
Tim
CLC Member #30850
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1977 Lincoln MKV
Walter Youshock
Another thing:  the tab on the mechanical strip that contacts the window frame should have a white plastic cover.  If it's missing, not only will ot scratch the hell out of the frame but can cause the strip to not push in as far as it should.
If the plastic is missing, wrap the tab with a couple layers of masking tape, close the door and see how it seals.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Cadillac Jack 82
I know that the mechanical strip has the white piece of plastic...its present.  Tell you what I'll take some photos when I pull the car out of my storage unit tonight when I go cruising and post them here.  Its not that serious of an issue but since the vent window doesn't seal properly it can cause water to leak in should I get caught in a rain storm.
Tim
CLC Member #30850
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1977 Lincoln MKV
Walter Youshock
Are the strip springs rusted?  Replacement springs are available.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
59-in-pieces
Tim,
At the risk of sounding way dumb, is it possible that the door hinges are in need of a tweak, and the door is sagging.
Not a 57 closed car - but a 59 convrt, I had a little gaposis in the vent window area, and solved it by adjusting the door hinges which realigned the door - no more gaposis.
Ok, I'm behind a boulder - take your shots.
Have fun,
Steve B.
S. Butcher
Cadillac Jack 82
Springs seem fine and I know where to get the replacements.  I'll take a second look again this evening just to be sure though.
As far as the door not being aligned properly it closes just fine.  If you look down the window when its closed you can see that the vent window frame is not aligned properly an bends off at a slight angle away from the door.  I'll snap photos tonight.
Tim
CLC Member #30850
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1977 Lincoln MKV
