1953 speedometer cable
Started by broadcreek, October 11, 2015, 10:39:50 AM
broadcreek
My current speedometer cable is causing the speedometer needle to bounce around a lot. I've lubed the cable but it doesn't help. My attempts to buy another cable have not worked out. Can anyone recommend a reliable source? Thx
tturley
Member # 28929
1940 Lasalle model 5019
1995 Ford F-150
2015 Buick Enclave
Dan LeBlanc
Have you taken the speedometer apart to check the worm gear?  That's a common failure point in these units from failing to lubricate the wick.
Dan LeBlanc
Dave Ventresca
or the magnet in the head is worn which causes needle to jump around. Dave
Bob Schuman
I recommend Dick Reynolds in Naples, Florida if you need a complete new cable assembly. Last year he made one for my 49 Cadillac and it fit and works perfectly. His phone is 941-643-4103.
Bob Schuman, CLC#254
2023 XT5
broadcreek
Thanks for all the leads___ I'll check these out.
55 cadi
One more to check into is "allcads" in Las Vegas.
Has a lot of original parts, I walked his inventory and wow.
And he has repop.
1955 Cadillac sedan series 62
2005 Cadillac deville
