All Cads
Author Topic: Rough weekend for a cruise  (Read 2253 times)
Offline 55 CDV Fan 82
  • CLC Number: 30850
  • Name: Tim Neumann
« on: October 11, 2015, 11:25:22 AM »
So this was a great weekend for cruising...sun is out...temperature is nice...however I've run into some issues.  First and foremost my tire decided to kick the hubcap off sometime on Friday evening.  Found a replacement but as you can imagine it wasn't cheap (175).  Now this morning it appears as if my generator has died.  The GEN light kicked on after the generator started making a noise.  I suspect maybe a bad bearing but who knows.  Does anyone have any hacks to see if I can get it working again?  I have a big car show next Saturday and I want to make sure this sucker is working properly.
Tim
CLC Member #30850
1955 Cadillac Coupe Deville "Evelyn"
1967 Buick Wildcat Convertible "Joyce"
Past Cars
1937 LaSalle Opera Coupe "Adeline"
1940 Chevrolet Coupe "Scarlett"
1941 Ford 11Y truck
1954 Buick Special 48D
1955 Packard Clipper Super Panama
1957 Cadillac Series 62 Coupe
1962 VW Bug
1962 Dodge 880
1966 Mercury Montclair
1968 Chevrolet Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln
  • CLC Number: 30850
  • Name: Tim Neumann
Re: Rough weekend for a cruise
« Reply #1 on: October 11, 2015, 12:07:39 PM »
Tested the generator...its only pushing out .68 volts....so for the most part its shot.  If anyone has an extra one laying around that they would be willing to sell please let me know.  Also I'm having a problem with a fast idle which wasn't an issue before...whats causing this?
Tim
CLC Member #30850
Past Cars
1941 Ford 11Y truck
1962 VW Bug
1962 Dodge 880
1977 Lincoln
Offline Walter Youshock
« Reply #2 on: October 11, 2015, 02:12:04 PM »
Feel your pain.  Took mine to Hershey Friday night and got stuck in the route 81 parking lot from hell.  Gen light started to faintly glow until I got off the hi way and got moving again.  Plan was to attend a CLC show in New Jersey today and return home--great trip.
6:30 this morning, the light popped on bright on the way to the second show of the weekend.  Swapped regulators (I always carry a spare), pulled the generator apart and cleaned the commutator.  Nothing.  Came home on a roll back...
Get used to it, my friend.  It's baptism by fire.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Offline Scot Minesinger
« Reply #3 on: October 11, 2015, 08:54:40 PM »
Tim,
There is a great list of recommended parts and supplies that it is always good to carry with you.  Sandy K the CLC Potomac Region secretary has the list.  Aside from the starter and water pump I always carry them (alternator, voltage regulator, and etc.).  If I take a long trip then the water pump, starter and floor jack go in the trunk.  Also, there are special tools too, such as for my 1970 you need an 1-1/4" wrench and a 1" tubing wrench for fuel work.  I carry a few other parts for my friends too.  One time a friend in a 74 Cadillac with optional electronic ignition was towed to the car show on a roll back, and I repaired his car by replacing the coil in distributor cap.  He drove home and it reams in place five years later.
Once you get all the bugs out, your car should be reliable.
Offline Jeff Rose CLC #28373
  • CLC Number: 28373
  • Name: Jeff Rose
« Reply #4 on: October 11, 2015, 11:09:58 PM »
I dont have much to say, other than I understand my friend.
Jeff Rosansky
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
Offline Philippe M. Ruel
« Reply #5 on: October 12, 2015, 01:08:38 AM »
Remove the belt and try turning the generator pulley. If it makes noise, the bearing may be faulty. No other solution than a repair or exchange. Most any 12V Delco generator will fit - from any GM car, truck, tractor of the late 50s or early 60s - till you get the correct one or repair yours.
If no bearing noise, disassemble and check carbon brushes. These are "wearing parts" and should be replaced after years of use.
New brushes for a Delco generator must be in the $5-$10 range. Not easy to find in Europe, I don't know if they are available at the parts store next block in the US. If so, clean commutator with emery cloth, and install new brushes. Any auto electrician can do the job - and may provide for new brushes - if you are not sure how to do it.
1952 60 Special in France.
Offline Gene Beaird
  • Name: Gene Beaird
« Reply #6 on: October 12, 2015, 10:21:22 AM »
And IF you have a Factory Service Manual, it should explain the steps to rebuild your generator yourself.  They're usually pretty good at that.  I know the FSM for our 68 Calais does an excellent job on the process to rebuild the alternator, and refreshing the points.   :D
And I'd add a jack stand, or two to that kit that goes in the trunk with the floor jack.  Floor jacks can fail unannounced, so it's always safe to have the car sitting on stands if you're under it.  Good luck!
Gene Beaird,
1968 Calais
1979 Seville
Pearland, Texas
CLC Member No. 29873
Offline walt chomosh #23510
« Reply #7 on: October 13, 2015, 09:55:23 AM »
Tim,
  I had two generator failures on my 1955CDV and that was enough for me! I installed an GM alternator(commonly available at any parts store in the country) and have never had a problem since. The local overhaul shop told me that replacement parts for generators are now all low grade Chinese made junk. My car is a driver and I demand reliability....walt...tulsa,ok
  • CLC Number: 30850
  • Name: Tim Neumann
« Reply #8 on: October 13, 2015, 10:38:33 AM »
Well I was lucky to find a used but rebuilt generator for only 100 bucks on Ebay.  Its a late 50s/early 60s Generator and its an exact match to what was on my car when I received it.  Looks like the generator was a rebuilt model as well and I suspect (without pulling it apart) that the bearings went bad as previously mentioned.  My replacement generator will arrive in the next few days so hopefully the issue will be resolved by then.  Again its not that big of a deal but it can certainly bring down ones spirits when you want to go cruising.  Wish me luck and hopefully I'll see some of you at the Rockville Carshow this coming weekend.
Tim
CLC Member #30850
Past Cars
1941 Ford 11Y truck
1962 VW Bug
1962 Dodge 880
1977 Lincoln
  • CLC Number: 30850
  • Name: Tim Neumann
« Reply #9 on: October 15, 2015, 09:30:05 AM »
Hubcap replaced...it was kinda tough getting it on last night but it popped on.  Any good tips for keeping these suckers on?  I've gone around the edges with a rubber mallet and they seem secure but I do not want to be replacing more of these in the future (cost=175!)
Generator is out on the truck for delivery today.  Wish me luck!  I'll install this after I get home from work and test it out.
Tim
CLC Member #30850
Past Cars
1941 Ford 11Y truck
1962 VW Bug
1962 Dodge 880
1977 Lincoln
Offline Dan LeBlanc
  • Name: Dan LeBlanc
« Reply #10 on: October 15, 2015, 10:47:00 AM »
Don't forget to polarize it after installing it before you start the car.
Dan LeBlanc
  • CLC Number: 30850
  • Name: Tim Neumann
« Reply #11 on: October 15, 2015, 12:09:35 PM »
Will do.  That's just taking a wire (or screw driver) and briefly tapping B and A on the voltage regulator, right?
Tim
CLC Member #30850
Past Cars
1941 Ford 11Y truck
1962 VW Bug
1962 Dodge 880
1977 Lincoln
« Reply #12 on: October 15, 2015, 12:10:43 PM »
Yep
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
  • CLC Number: 30850
  • Name: Tim Neumann
« Reply #13 on: October 15, 2015, 10:27:11 PM »
Success!  Installed the new generator, polarized it, then fired my car up.  Started right up no issues and everything electrical works 100% great now.  Tested the generator and its pushing 15.51 volts at idle.  The only thing I see that may be an issue (or perhaps an adjustment) is I have a faint glow of the GEN light when parked or when accelerating.  When I place the car in drive, reverse, or when I come to a complete stop the GEN light fades out.  The glow is very faint but its noticeable.  Whats causing this?  Too much tension on the belt?  Voltage regulator adjustment?
Tim
CLC Member #30850
Past Cars
1941 Ford 11Y truck
1962 VW Bug
1962 Dodge 880
1977 Lincoln
« Reply #14 on: October 16, 2015, 12:56:43 AM »
Way too much.
It should be in the 12-13 V range at idle (12.5-13 for an alternator), and not exceed 14.5 at high rpm. Have you checked output at, say, 2,000 rpm ?
The regulator should be checked and adjusted, it may be the cause for former generator failure.
Offline Glen
  • CLC Number: 727
  • Name: Glen Houlton
« Reply #15 on: October 16, 2015, 01:03:09 AM »
Phillippe beat me to it.
It could be the voltage is too high causing the light to come on.  Normally the charging voltage for a 12 volt battery is around 14 volts give or take a couple of tenths.  15.5 will boil the battery.
Glen Houlton CLC #727
CLCMRC benefactor #104
  • CLC Number: 30850
  • Name: Tim Neumann
« Reply #16 on: October 16, 2015, 06:04:07 AM »
Okay figured it was a bit high.  I have the tension really tight so I'll back it off a bit and retest.  Anyone have a chart I can use for the voltage regulator adjustment?
Tim
CLC Member #30850
Past Cars
1941 Ford 11Y truck
1962 VW Bug
1962 Dodge 880
1977 Lincoln
« Reply #17 on: October 16, 2015, 06:04:55 AM »
Regulator needs to be adjusted.  I wouldn't drive the car until it's fixed.
Now get the original generator rebuilt and you'll be all set!
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
  • CLC Number: 30850
  • Name: Tim Neumann
« Reply #18 on: October 16, 2015, 08:56:53 AM »
Okay I would like to correct a portion of my last post so that I can get the best advice to get this adjusted.  I have a very big show tomorrow and I don't want to end up not going because something isn't adjusted properly.
When I tested the power output of the generator I tested it at the generator itself.  I used the negative wire and grounded it on the body.  The positive wire I placed directly on the contact at A.  The output reading on my voltage reader was 15.58 or so.  Based on a conversation I had with a coworker I should have tested this at the battery; first at idle and then at 2500 rpm.  With those readings I was told I'd know how to move forward.
Question:  Where and what do I need to adjust on the voltage regulator to ensure that I'm not frying my system.  Battery is brand new and the voltage regulator looks aged (may be original, may be an older replacement).  Its the old style Delco voltage regulator so I'm familiar with them as I had one in my 1954 Buick.  Any advice is greatly appreciated as I really need to make this car show tomorrow.
Tim
CLC Member #30850
Past Cars
1941 Ford 11Y truck
1962 VW Bug
1962 Dodge 880
1977 Lincoln
« Reply #19 on: October 16, 2015, 12:41:12 PM »
Measure it at the battery with car running.  The regulator is the "brain" of the system.  The cutout regulator is what's always on, off, on, off.  You really need a shop manual and an ammeter to adjust it.
How are the points on the 3 sections of the regulator?  Try some fine sandpaper and shine up the contacts.  You're sure you got a 30 amp (nnon air) generator...
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
