Art's 38 and 49 start very well. He is very correct about the importance of clean grounds and good connections. On the 49 especially, the lights are very bright. His grounds are good and his in next ions have been cleaned up. Last fall, not so great. After cleanup, very impressive. One thing to note though, the idle on the 49 is set slightly higher than the factory setting. Set your idle a little higher and you should be charging at all times like Art's car.
Hi, I have a '49 and found that I need to set the idle just a bit higher than the specs to have the ammeter pointing where I want under various situations.Why can't the generator pulley be changed with a very slightly smaller one so that it turns more when the car is set at the correct idle? This will give the generator more rpms while the engine rpm will not have to be set higher. Ray Schuman
Changing the pulley out for a smaller one will allow the generator to charge at idle but will over spin it at full engine RPM's. If only that was a practical solution the electrical systems designers of the day would have done it. I remember reading somewhere about Delco working on a pulley system that would somehow vary depending upon RPM to solve the problem but it was abandoned when alternators became a viable option.
Broe, in your first sentance you reaffirm. In the times in which they were built. If nothing is added, then it still is in the time in which it was produced. My 38, 49 are still, as they were produced. More then adequate. Had my 49 out today. Had ran in 8-9 days. Two turns and it fired right up. Ok, i understand updating for some but my question us the same, why???
