Correct LB radiator cap for 1957 Cadillac
Started by Cadillac Jack 82, November 05, 2015, 04:10:58 PM
Cadillac Jack 82
Should I use the 7 lb or 13 lb cap?  Reason I ask is my car temp gauge normally shows about 3/4s the way to H...sometimes a little bit less.  I've read that this is still within normal operating temperatures based on some articles I've found here.  I'm wondering if the radiator cap may be causing the car to run warm as the water pump and thermostat are brand new in the engine.
Tim
CLC Member #30850
1959 Cadillac CDV "Shelley"
1964 Cadillac SDV "Rosalie"
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1955 Packard Clipper
1957 Cadillac Series 62
1962 VW Bug
1962 Dodge 880
1966 Mercury Montclair
1968 Chevy Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln MKV
Jon S
My 1958 used to run between 1/2 and 5/8 (with the original cap). I had the radiator boiled out even though it drained nicely and since then it has been running at 1/4 with the same cap. I had it boiled out 10 years ago.
The cap is a 13 lb RC6:
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
Cadillac Jack 82
Yeah the radiator on this was rebuilt as well so I figure it has to be the cap or not a proper balance of coolant.  I don't worry too much because its not boiling and I don't have any boil over.  It'll get close to 3/4s on the gage and sit there.
Tim
CLC Member #30850
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1977 Lincoln MKV
Coupedeville
Hello Tim,
I have a 13lb cap on my 57 rad and the temperature gauge sits at 1/4 constantly, unless in heavy traffic.
Joe
Joe Hunt
Jon S
Jon
1981 Corvette
2004 Mustang GT
willits
Both my '58 and '61 sit right at 1/4 on the gauge.  I have 160 degree thermostats in both at 14lb radiator caps.  The needles do creep up at idle if the coolant is low.
Peter
Peter Willits
1958 Coupe DeVille http://bit.ly/1O6BGVu
1961 62 Convertible http://bit.ly/1O6BHst
2008 STS-V http://bit.ly/1O6CI3P
Cadillac Jack 82
I found this on an earlier post.  Mine sits in the middle and slightly to the right.  According to this old add that's fine?
Tim
CLC Member #30850
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1977 Lincoln MKV
Jon S
May well be - When my 1958 was brand new it ran at 1/4 on the hottest of days.  Since boiling out the original radiator, it is back at the 1/4 mark and has never exceeded it.  1/2 may be OK, but 1/4 is cooler.  I have a 180 degree thermostat in the car.
Remember, the gauge is only an indicator . . . it measures "relative" temperature.
Jon
1981 Corvette
2004 Mustang GT
Dan LeBlanc
Best thing you can do is take an infrared thermometer and take some readings to see if you're really running hot, have a gauge problem, or a sending unit problem.
Dan LeBlanc
Cadillac Jack 82
Awesome yeah I've purchased an AC Delco 13 lb radiator cap as the one that's on there looks old.  I'm going to top off the coolant and then test everything out.  Thanks everyone
Tim
CLC Member #30850
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1977 Lincoln MKV
