'60 Eldorado Biarritz frony door side molding needed
Started by Whit, November 05, 2015, 05:23:59 PM
Whit
After inventorying my outside molding removed by the previous owner, I find that I need the 'upper/lower' thin molding pieces that go on the front doors of my 1960 Eldorado Biarritz.
These are the thin molding pieces that 'curl upward' and terminate at the base of the vent window. I believe that they are P/N 478 5294 and
P/N 478 5295. On the Biarritz (6467) there are two upper moldings on the door...these are the lower ones (hence the 'upper/lower moldings nomenclature).
If anyone has these or could direct me to some, I would greatly appreciate it.  Thanks  Whit
