1940 lasalle transmission
Started by jmscan06, November 05, 2015, 09:04:01 PM
jmscan06
Does anybody know what transmissions are interchangeable with 1940 lasalle 5227 c. My interchange book states that 1940-1948 interchange but not 1939.  How can I verify that this is correct.
John Scanlan
Brad Ipsen CLC #737
41 to 48 do not interchange with 40 unless you take them apart and change the tail shaft and tail shaft housing.  The 41 and up have a different rear bearing which requires a different drive shaft spline.  38 to 40 big series cars have different rear mounts.  The good news is most internal parts that wear are interchangeable between all years 38 to 53 with some exceptions.  Best to rebuild what you have and get a good transmission of any year to salvage good parts from.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
jmscan06
Is a 1939 lasalle transmission the same as the 1940?
John Scanlan
All these transmissions will fit the back of any of the 346 engines but as Brad said the differences are in the rear sections. There may be different tail housing and support mounts plus the differences in the final drive shaft yoke. My MPB shows the 50 series as having the same yoke 39-40 so you should be OK there. The 1940 was a longer wheelbase but the difference could be just in the drive shaft.   If the box is the same length you should be OK 50 series to 50 series but you need to check it out first.
