Carb and air filter for 1962 390 needed in England.
Started by rustytractor, December 17, 2015, 07:37:57 AM
rustytractor
I have a 1962 Miller Meteor hearse in England that been fitted with an edelbrock carb and nonstandard air filter which I want to return back to stock.
I need the carb, choke tube, air filter, gaskets etc - basically everything from the manifold up other than the throttle and TV linkages and fuel lines.
I want a fully rebuilt and tested carb which is ready to go, happy to paint the air filter if it's not perfect.
I've place a wanted ad, I've also posted here so hopefully someone can point me in the right direction.
Thanks, Russ
Too many cars - too little time !!
russ austin
R.Austin
