1964 429 into a 1966
Started by okccadman, December 21, 2015, 02:55:38 PM
okccadman
a friend has purchased a rebuilt 1964 429 to put in his 66 DeVille Convertible.  He is having trouble.  Is there a trick to installing an early 429 where a later one was?
Jim Jordan CLC# 5374
Oklahoma City, OK
55 Series 62 Sedan
56 Series 62 Coupe
56 Fleetwood 75 Derham Limo
59 Fleetwood Sixty Special
66 Fleetwood Brougham
66 Superior Hearse/Ambulance
67 Fleetwood Sixty Special
68 Fleetwood Eldorado
76 Coupe de Ville d'Elegance
90 Brougham
92 Fleetwood Coupe
93 Allante
94 Fleetwood Brougham
02 Eldorado Commemorative Edition
savemy67
Hello Jim,
The '64 shop manual mentions an adapter plate when removing a TH400 from a '64 429.  Because '64 Cadillacs came with either a TH400 transmission or a Hydramatic transmission, I think the adapter plate was used only in '64.  Your friend's rebuilt '64 429 may be missing the adapter plate needed to mate with his '66s TH400 transmission.
Christopher Winter
Christopher Winter
1967 Sedan DeVille hardtop
russ austin
The motor mount location is different on the 65 and up years.  64 has the mount location close to the front of the block.  65 was moved to more the center of the block.
Its going to take frame surgery, or the correct block.
R.Austin
There was an article in the Self Starter about how different the 429 engine was year to year from 64 thru 67.  Contrary to the 472/500 series parts (and I guess frames) do not all interchange.
