removing cabin sensor from 1964 dash grille
Started by Bob Hoffmann CLC#96, January 07, 2016, 06:34:49 PM
Bob Hoffmann CLC#96
Guys, I have a nice dash grille that still has the cabin sensor in it. What is the correct way to remove it? Help.
Thanks, Bob
Jason Edge
The dash pad (instrument panel cover using Shop Manual lingo) needs to be removed to access a 3/8" nut behind a bracket that holds the in-car sensor in place.  The sensor body turns and locks into the plastic grill assembly.  Bottom line, is remove the dash pad, and use a 3/8" deep socket to remove the retaining nut. See picture below:
Jason Edge
Lifetime Member
Exec Vice President
CLC MRC Benefactor
2002 Escalade EXT - Black
Bob Hoffmann CLC#96
Jason,
I have the grille out. It seems like the sensor turns pretty hard. Do you twist it one way or the other??
Thanks, Bob
Jason Edge
I don't remember it going one way or the other, but I never remember much issue getting it to twist out. You might put a couple drops of WD 40 at the base where it turns. Be careful with the grill as it is brittle.  I've removed 3 dozen and never broke one yet but I know they are very brittle as I often seen them broken up in parts cars I bring in.
Jason Edge
Lifetime Member
Exec Vice President
CLC MRC Benefactor
Jason Edge
I just tried one I just pulled out of a parts car and you can turn it counter clockwise or clockwise to remove sensor assembly from the plastic grill. You just need to get the length of it's base of the sensor to line up with the elongated opening of the sensor grill. I just used a 2 fingered firm grip at base of the plastic grill and a firm grip with other hand on sensor base and turned.  A bit of pressure but not that much.
Jason Edge
Lifetime Member
Exec Vice President
CLC MRC Benefactor
Bob Hoffmann CLC#96
#5
Jason,
I removed it. Had to grab the sensor with a pliers. It was tight! No breakage.
Thanks, Bob
