Pre Bent Brake Lines
Started by Virgil Perkins, January 15, 2016, 09:22:12 PM
Virgil Perkins
Looking for new source for pre bent brake lines, steel and stainless both, in addition to Inline Steel. I had good results with Inline in 2004 but have noticed several complaints recently. Thanks in advance for any references with good experience. VP
Virgil Perkins
Jeff Maltby 4194
I purchased my 49 lines from them some years ago with all fitting properly less the left rear drum like to junction block . I sent them mine after telling them theirs was incorrect and paid them to redo it properly, so hopefully they used mine as a new pattern ?
Jeffo 49er chapter
CLC 1985
Honda Gold Wing GL1500
39lasalle
I got mine from kantor out of New Jersey about 10 years ago.   Not sure where they source them from.    Went right on with no issues
39
JoeKarasinski
I got mine from inline recently. I have no complaints.
Bobby B
Virgil,
Hi. I've  also used Inline and Classic with no problems. Invested in a few different style benders and Hydraulic set-up years ago, and do my own. If you have the existing lines, you already have the template. You can buy all the tubing/ends you want in bulk, and save yourself a lot of money.
        Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
Virgil Perkins
Thanks to all for response and pm regarding Inline Tube (not Steel as I incorrectly posted).
Virgil Perkins
sudsytimmy
Hi All,
This is my very first post, but it's right on topic.
Does anyone know where I can source pre bent brake lines for a 1984 Seville?
I looked at the places mentioned above and did not see the lines for this year and model.
Thank you very much!
Tim
chrisntam
Got mine for my '70 from Inline Tube.  Bends were correct, pretty much went together without too much of an issue.   I got the stainless lines, had to loosen / retighten the fittings a few times to get them to seal.  No issues since.
chris.
1970 Deville Convertible
Dallas, Texas
