jacks
Started by Las32, January 22, 2016, 12:02:44 PM
Las32
Can someone tell me what is the jack that was supplied with the 1932 LaSalle 345B?  I think it was a Drednaut, but I don't know whether it was a screw or a bottle jack nor what the top looks like.
Wayne Womble 12210
Probably a Buckeye #2.
Las32
I think the Buckeye jack is one that is operated by an up-down motion of the handle.  My LaSalle has an overhang that requires a activating handle that muse be turned not pumped.
Warren Rauch #4286
  There is a picture of the jack in the 1932 LaSalle owners manual on page 40. It is clearly a screw  jack. I know nothing about jacks,so you will have to tell me the brand. Warren
Johan Boltendal #158
It's an AutoSpecialist  jack with  the '32
Las32
Warren, Can you actually see a screw where the lift leaves the body or is it a hydraulic piston?
Warren Rauch #4286
  The picture is the tool storage area in the front seat. It shows the screw at the top and the gears to turn it quite clearly. The manual I have is  a copy, but I just photo copied it and  will send you a copy. it is clear enough to work from. Warren
