1969 cad limo caliper clip question
Started by 1969cadillac, January 26, 2016, 04:52:42 AM
1969cadillac
hello , on a 69 deville on the front brake caliper , I am concerned about the placement of the antirattle clip - please see pics attached !
If you put it in where it looks like it is meant to go , as per the shop manual.....
my only concern is that when the pads wear down.... the ends of the clip will contact the disc!!
ant thoughts?? , regards , Murray Mules
Glen
Is it possible that that is exactly what it is supposed to do?  Many cars have a low brake pad warning.  It is a piece of thin steel that causes a noise when the pads are worn.
Glen Houlton CLC #727
CLCMRC benefactor #104
