Bruce,I have an 80 Eldo that starts and runs just fine but who know when the day will come that the ECU decides to become a problem. Please keep us informed.Brian
Cool news. I'm sure it was quite a project. There is an issue looking for a mechanical type. I have figured out how to convert 76-77 Seville ECUs to substitue for the extremely in short supply 76 500 ECU. Problem is the mounting brackets are different, so someone needs to volunteer to make some 500 brackets that can be attached. I'm guessing when the 80's and newer ones start failing the 'fix' will be a current ecu with the special programming and plugs to fit the existing system. I would imagine the 80's will have a few parts that could be repaired but most components would be like the 'ceramic' that Bruce had to reverse engineer in this case, just there will be dozens of them instead of a couple.
Jeez Bruce, What an amazing setup you have. Thanks for sharing it.2 questions: Do the injectors fire into the intake manifold or the head, and when it fires 1 bank and then the other, does it fire all 4 at the same time? Not the best timing wise, but seems like it would be easiest given the technology of the time. Is there a crank position sensor or does it just pull its info from somewhere else..... OK, that was 3 questions. Thanks, Jeff
In every 76 EFI Cad, and most 77s, is a big ceramic circuit board. This 2" X 3" part has 25 pins, 4 custom and unavailable integrated circuits, and dozens of other parts. Usually when a ceramic fails, it can't be repaired. A big problem. I have been studying the ceramic for a long time. I finished designing and ordered a circuit board which I hope, will directly replace the ceramic. It won't be ready for prime time for a while. Bruce Roe
