Founded 1958
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Forum Rules
Calendar
Login
Register
CLC Home
Forum Rules
General Discussion
(Moderators:
Lars Kneller 8246
quadfins
Barry M Wheeler #2189
Bill Hedge CLC 14424
'60 Biarritz Mystery Part
All Cads
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: '60 Biarritz Mystery Part (Read 1608 times)
Whit
on:
February 25, 2016, 07:17:48 AM »
I have asked this question before, but no answer. Attached is a photo of a check valve (I think) on my manifold. I don't know what it does or what is supposed to be connected to it. Can someone help clarify this for me?
Thanks Whit
Logged
55 CDV Fan 82
CLC Number: 30850
Re: '60 Biarritz Mystery Part
Reply #1 on:
February 25, 2016, 09:14:32 AM »
Looks as if it might be a temp sensor? If it were a more modern car I'd say fuel/air mixture but not with something that old
Logged
Tim
CLC Member #30850
1955 Cadillac Coupe Deville "Evelyn"
1967 Buick Wildcat Convertible "Joyce"
Past Cars
1937 LaSalle Opera Coupe "Adeline"
1940 Chevrolet Coupe "Scarlett"
1941 Ford 11Y truck
1954 Buick Special 48D
1955 Packard Clipper Super Panama
1957 Cadillac Series 62 Coupe
1962 VW Bug
1962 Dodge 880
1966 Mercury Montclair
1968 Chevrolet Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln
Whit
Reply #2 on:
February 25, 2016, 09:24:50 AM »
Tim:
Thanks for the reply, but it definitely is not a temp. sensor. It is some sort of check valve, but I don't know what for or what it connects to.
Whit
Logged
Eric DeVirgilis CLC# 8621
Name: Eric DeVirgilis
Reply #3 on:
February 25, 2016, 10:44:11 AM »
Vacuum fitting?
Logged
quadfins
Jim Eccleston
Administrator
CLC Number: 16079
Reply #4 on:
February 25, 2016, 11:04:17 AM »
Re: '60 Biarritz need help
« Reply #10 on: February 18, 2016, 04:12:15 PM »
I am working from memory here, from a '60 manifold that I removed for a friend some years ago, so others may have better info...
IIRC, that fitting is the vacuum source for the devices in the passenger compartment. Namely, the parking brake release, and any heater/AC actuators that run on vacuum. A small hose runs to the junction box on the firewall (it also has a bunch of wires). This connector mates the hose and wires from the engine compartment to the corresponding ones in the interior. The vacuum hose plugs into the inside nipple, and then goes to the neutral safety switch, from which it is routed to the brake release actuator.
The junction box is that one located under and to the side of the brake booster.
On my '61, the vacuum source is a brass fitting, on the same side, but at the rear of the manifold. There is a check valve inside the passenger compartment, and also serves to split the sources of vacuum to the brake release and the heater/AC system. I thought that, on '60s, the check valve is integral to the fitting on the intake manifold.
Jim
Logged
Jim Eccleston
1961 Coupe de Ville
BATILAC
Senior Crown
DeCou Driving Award x 4
Reply #5 on:
February 25, 2016, 11:36:33 AM »
Jim...I concur.
Subject car does not appear to have A/C though I could not say for certain from the photo provided. Power door locks on 1960 were electrically actuated so it wouldn't be for that either. Forget about whether power trunk release was electric or vacuum in 1960 - probably electric as well.
However, auto parking brake release was standard in 1960 so it could well be for that.
Logged
quadfins
Jim Eccleston
Administrator
CLC Number: 16079
Reply #6 on:
February 25, 2016, 01:38:45 PM »
What operated the fresh air inlet duct for the heater in 1960? Would that also use vacuum, as it did in '61?
Power trunk in '60 was electric, as you say.
Jim
Last Edit: February 25, 2016, 01:40:20 PM by quadfins
Logged
Jim Eccleston
1961 Coupe de Ville
BATILAC
Senior Crown
Whit
Reply #7 on:
February 25, 2016, 03:54:12 PM »
Just to clarify a bit...my '60 Biarritz does have A/C. The heater-A/C distribution case on the firewall has three vacuum actuated diaphragm devices to open and close various gates to divert air through the heater core, defroster or the A/C evaporator. I 'think' the vacuum line to that system may come from the check valve on the manifold that is shown in my photo (but I'm not sure). What makes me question that is that the size of the curved stainless tube shown in the photo is only about 1 mm in diameter (about 4 times the size of a hypodermic needle. That seems small for a vacuum source for three diaphragms and the dash switching network. Check the diagram of this system below.
I'm still struggling with the correct under hood vacuum tubing connections. Any help understanding this will be much appreciated.
Whit
Logged
quadfins
Jim Eccleston
Administrator
CLC Number: 16079
Reply #8 on:
February 25, 2016, 04:10:41 PM »
Is there a similar fitting on the passenger side? If not,, then according to the vacuum diagram, it is the source for the vacuum actuator for the AC.
I think, on standard manifolds, the fitting was on the passenger side
Perhaps, though, this may not be for the parking brake.
Jim
Last Edit: February 25, 2016, 04:13:01 PM by quadfins
Logged
Jim Eccleston
1961 Coupe de Ville
BATILAC
Senior Crown
savemy67
Reply #9 on:
February 25, 2016, 07:31:41 PM »
Hello Whit,
If I recall correctly, the GM 3 x 2 carburetor arrangement had the middle carb function as the primary venturis and the front and rear carbs function as the secondary venturis (someone correct me if this is not the case for Cadillacs). The vacuum fitting is located in the intake manifold runner near the front carb, so under most driving conditions the vacuum signal would be relatively high. Additionally, since pressure or vacuum (negative pressure) is a function of cross-sectional area, a small diameter tube would not necessarily be a problem. The shop manual may indicate that the vacuum needed to operate the various vacuum operated devices is much less than the vacuum provided by the fitting. You can connect a vacuum gauge to the fitting to see how much vacuum you have.
Respectfully submitted,
Christopher Winter
Logged
Christopher Winter
1967 Sedan DeVille hardtop
CLC Number: 22443
Reply #10 on:
February 25, 2016, 08:10:19 PM »
Whit,
You have that correctly identified at the Manifold Vacuum Check Valve. The thin tubing goes onto a stem mounted high on the firewall. I went into the garage to look at the connection for you but I have the car under another one on my lift and I cannot raise the hood high enough to snap a photo for you.
I may take the car out in the next few days and will take a look. The car is a non AC car with tri power.
Logged
CLC # 22443
I prefer email's not PM's rachlin@comcast.net
Whit
Reply #11 on:
February 25, 2016, 09:13:08 PM »
Brian:
I will look for a 'stem' high on the firewall...not sure that I have seen that. I thought on my car (with A/C) the tube went through the firewall mounted blower unit inward to the dash mounted A/C controls (as per the diagram above). Vacuum lines are distributed onward from there to the heater and A/C distribution unit.
Thanks to all for your kind input. Whit
Logged
David Greenburg
CLC #3830
CLC Number: 3830
Name: David Greenburg
Reply #12 on:
February 26, 2016, 01:38:06 AM »
Whit-
I had a chance to look at mine (with a/c). The hose runs from the outlet on the vacuum port, between the carbs and then to the firewall, where it enters the middle port on the firewall junction block located just below the silver vacuum actuator located on the passenger side firewall. I tried to take a picture, but the lighting was bad. If you need a picture, I can try and take one in the daylight over the weekend.
Logged
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
Whit
Reply #13 on:
February 26, 2016, 06:56:21 AM »
Thanks David. I will check today to see if I can understand where that location is. A photo would really help. I 'think' you are talking about the holes in the blower unit where the three vacuum tubes enter and exit. Is that correct?
I have not as yet installed the blower unit. but I am aware of the location of the passage for the three vacuum tubes.
Thanks Whit
Logged
David Greenburg
CLC #3830
CLC Number: 3830
Reply #14 on:
February 26, 2016, 11:40:17 AM »
Whit:
Yes; that's it exactly.
Logged
David Greenburg
Print
Pages: [
1
Go Up
« previous
next »
General Discussion
(Moderators:
Lars Kneller 8246
quadfins
Sitemap
1
2
3
4
5
6
7
8
9
10
11
12
13
