Just need to know if the upper chamber requires a air tight seal for my sanity.
Yes. Fuel filters came installed from the factory.
You're right TJ, it does seem counter-intuitive when you think about it. I was a little quick in just trusting my memory on this one. I couldn't recall ever seeing those two 90 degree elbows which are required in order to flip the filter and not have clearance issues. This screenshot is from a 58 instructional video on the new 3x2 carb setup clearly shows the filter upside down. Why would it be different in 57?The return hose from top of the filter is also very visible on this AC car.
