1958 air cleaner hoses
Started by Vikingrental, March 06, 2016, 09:16:53 PM
Vikingrental
My 60 special is just about ready to start up, but I am stuck on the air cleaner hose connection. The car has air ride. The air compressor inlet hose connects to one side of a T fitting on the air cleaner to get filtered air. What hose connects to the other side of the T? Currently it is blocked off with a short piece of hose and a screw but I highly doubt this is correct. Any ideas?
David King (kz78hy)
I think the other line is from the exhaust side of the lift valve.
This car is different from my Brougham, I have not yet gotten into the air system on the 59 which is similar to yours.
Is there a diagram in the 58 service manual supplement?.
David
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
Pretty sure Dave is right.   I was looking for an air cleaner and I found one but it had the hose connection which mine did not.  During figuring out what it was, I saw it was for air ride.   Not sure where I found info.
I have a manual and alot of other documents.   If you need a diagram or something.
