1955 cadillac fleetwood steering shaft
Started by waynehawaii, March 10, 2016, 12:03:45 PM
waynehawaii
anybody know if steering shaft was tempered steel?
may need to weld so info would be appreciated
aloha
walt chomosh #23510
Wayne,
  A simple spark test will show if the shaft is heat treated. Also,running a file across the metal will show the hardness.....wonder where you plan on welding and why....walt...tulsa,ok
