Horn ring assembly 1956
Started by Saturnin15, March 18, 2016, 05:42:45 PM
Saturnin15
I have problem figuring how to reassemble my horn ring.  What is the proper sequence?
Sedan Deville 1956
J. Gomez
Eric,
From the picture you posted the plastic emblem and a thing metal plate is missing, so the order is;
1-   Plastic emblem
2-   Thing metal plate
3-   Your picture A (flipped around)
4-   Your picture gasket D
5-   Your picture B
6-   Last your picture C
You need to make sure the piece on your picture A does not make contact with any of the pieces B or C or the metal base on the ring.
The gasket D goes on the outer edge of A (once is flipped around) keeping it isolated from metal-to-metal contact with B and C.
Hope this helps..!
J. Gomez
CLC #23082
