AC Delco upper engine cleaner
Started by Flathead16, April 25, 2016, 11:56:56 AM
Flathead16
Has anyone used the GM upper engine cleaner to decarbonizing your piston and valves? With the lack of timing in the 1938-1940 V16s carbon is a problem and could cause some of the valve sticking problems and weak spring combination.
Thank you, Steve Loechner
Jon S
I would think Sea Foam (a modern day version of Carb Out) would work.
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
cadman59
A couple off days ago I stumbled on a message in this old topic. Maybe that would work for you too. At least it seems to be a "period-correct" method  ;D.
Feiko Kuiper - Netherlands (Europe)
1959 Cadillac Series SixtyTwo 6-Window Sedan
https://instagram.com/feikokuiper
