All Cads
Author Topic: How best to store R-12 freon cans?  (Read 2162 times)
Offline chrisntam
  • Dallas, Texas
  • CLC Number: 29206
  • Name: Chris Jessen
« on: April 28, 2016, 09:45:48 PM »
I was at the swap meet today, picked up a 12 pack of R-12 1 pound cans.  Plan on storing it until needed when my certified a/c mechanic may need to recharge the system.
How is it best stored for the long haul (years) so it won't leak out?
Any ideas?
1970 Deville Convertible
Dallas, Texas
Offline jsanford
  • Name: Jeremy Sanford
Re: How best to store R-12 freon cans?
« Reply #1 on: April 29, 2016, 12:37:44 AM »
Just keep them in a cool dry place. The only reason they would leak is if they rusted through from outside moisture.
Jeremy
Jeremy
Sacramento, CA
1981 Eldorado
2016 ELR
« Reply #2 on: April 29, 2016, 11:02:55 AM »
Chris,
I think they are probably 12 ounce cans.
Offline Jon S
  • Name: J. Schapiro
« Reply #3 on: April 29, 2016, 01:49:36 PM »
Better way to store them - send them to me!
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
Offline chrisntam
  • Dallas, Texas
  • CLC Number: 29206
« Reply #4 on: April 29, 2016, 02:33:04 PM »
Chris,
Yes, the 12 ounce cans as opposed to a 30 pound drum.....I ended up paying about $16 per can yesterday.
I passed on a thirty pounder for $380.   I recall passing on Freon back in the day when is was $0.99 per can.   ::)
Dallas, Texas
Offline 76eldo
  • CLC Number: 22443
  • Name: Brian Rachlin
« Reply #5 on: April 29, 2016, 03:04:15 PM »
Grab the 30 pounder for $380.
That's a great deal if it's a sealed can.
CLC # 22443
bill06447
  • Guest
« Reply #6 on: April 29, 2016, 08:54:49 PM »
If the can leaks it's empty. I just bought 9 on eBay came to 20 a can including shipping...6 14 oz and 3 12 oz they all had Kmart price stickers $1.05!
Bill
Offline bcroe
« Reply #7 on: April 29, 2016, 09:20:56 PM »
I still have R12 around here, but decided not to use it until new
barrier hoses are put on.  When its gone, I'll be using the dirt cheap
propane-butane combination.  Bruce Roe
Offline 76eldo
  • CLC Number: 22443
« Reply #8 on: April 29, 2016, 09:41:27 PM »
Bruce,
That's a dangerous option.  If you have a sudden leak anywhere it could be a disaster.
I'd think about that one...
CLC # 22443
Offline bcroe
« Reply #9 on: April 29, 2016, 09:55:40 PM »
Bruce,
I'd think about that one...   Brian
I already had a trial run after getting a charge from a Cad owner outside
the USA.  It worked quite well till it leaked out.  No one has convinced
me 1.5 lb of propane is as dangerous as the 200 lb of gasoline I
carry around.  There is a 500 gallon tank of propane connected to
pipes running around my house, which worry me much more.  Bruce Roe
Offline fishnjim
  • Name: J. Bozin
« Reply #10 on: April 29, 2016, 10:36:58 PM »
I used to make some refrigerants and blends but not my main job.   R-12 is still in production in China for a few bucks a pound as far as I know.   Just "google" it.   But I believe it's illegal to import/sell in small cans in US thanks to the EPA.  But they're on ebay???   It's one of those you can't make it in certain places, if they signed the Montreal protocol, but some can use/make if they didn't, just don't put in the atmosphere if you did, silly regs.   One has to be "certified" here.   Which is not hard to do.   So don't hoard it quite yet.   This whole subject is held hostage in insanity by the EPA, so if they do global warming regs, might as well move someplace else.   We'll be permitted to breath out CO2 on even days or something.
Of course, unless you source directly, you get gouged.   If you have to pay that kind of money, you pay for the conversion.   A certified refrigerant tech can obtain it in =>20 lbs still as far as I know, even 22.   I don't know how they got around the certification requirement for 134a which you can get at the DIY parts store.
The new holy grail refrigerant coming out is 1234yf.   Diamler had issues in testing and has not approved it, but most everyone else is going to it.  Slight risk of fire but nothing like the alkanes.
There are some commercial blends that perform well in 12 systems but may not be available for mobile sources.   Talk to a local HVAC person or auto shop and see what they pay for a 20 lber or what to substitute.   Where there's a will...
fyi: https://www.epatest.com/609/manual/609_section3.html
http://www.gpo.gov/fdsys/pkg/CFR-2015-title40-vol18/xml/CFR-2015-title40-vol18-part82-subpartF.xml
Offline Jeff Rose CLC #28373
  • CLC Number: 28373
  • Name: Jeff Rose
« Reply #11 on: April 29, 2016, 11:58:00 PM »
A vault!
Jeff Rosansky
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
« Reply #12 on: April 30, 2016, 12:43:16 AM »
Bruce,
While Propane/Butane mix is an excellent refrigerant I does not mix well with the lubricants required for operation (compressor, moving valves/components) of systems originally intended to use R-12 and mineral oil.
Offline bcroe
« Reply #13 on: April 30, 2016, 10:53:25 AM »
Bruce,
While Propane/Butane mix is an excellent refrigerant I does not mix well with the lubricants required for operation (compressor, moving valves/components) of systems originally intended to use R-12 and mineral oil.  Greg Surfas
That could be a problem; didn't show up on the trial a couple decades ago.
I think the only moving parts in my R4 systems are in the compressor.  Bruce
Offline gary griffin
  • garygriffin@Q.com
  • CLC Number: 26430
  • Name: Gary Griffin
« Reply #14 on: April 30, 2016, 11:17:39 AM »
Bruce, I would be more concerned about the propane/butane under the hood and blowing back to my cabin if I were driving then the gas in the rear of my car, So many possible ignition sources under the hood and and so few in the rear area.  Any loose wire could ignite the mixture if there was a leak and then??
I was considering alternate gases for my 1957 A C but Greg Surfas seminar at Grand National convince me it would be preferable to stick with R-12
« Last Edit: April 30, 2016, 11:20:05 AM by gary griffin »
Gary Griffin
« Reply #15 on: April 30, 2016, 12:18:57 PM »
Bruce,
The compressor does need oil so if it does not circulate it will eventually run dry.  In regards to the rest of the system, all the components such as any orifice devices or heat transfer surfaces were designed anticipating there would be a film of oil, or actual "puddles" of oil in the expected locations in the system. If you are going to use anything other than a known and numbered refrigerant I would be sure and determine which lubricant would suffice.  Just a little chemistry, thermodynamics, fluid flow and lubricity studies should get you to the place where you could find a lubricant that might be effective.
Another factor is the critical temperature of Propane is a full 30 degrees (F) colder than R-12, so in extreme conditions where you have exceeded that temperature under the hood, Propane will not condense, regardless of the pressure applied, and your cycle stops.
That said, let us know about the longevity and performance as you experience it.
Offline bcroe
« Reply #16 on: April 30, 2016, 12:36:10 PM »
I am no chemical engineer, but the Cad owner who introduced me to this
alternative is.  Lately I have just let the A/C in my cars leak down and be
unused; saving my last R12 for a "special event"?  The weather typically
just isn't that hot here, and the 70 mph breeze helps.  The year I get back to
this, perhaps I'll try something different in each car and see what happens.
If we really need air, there is the Honda which never seems to lose its charge.
Bruce Roe
Offline Dynamic88
  • Name: T King
« Reply #17 on: April 30, 2016, 09:38:06 PM »
I agree. Hopefully soon all the "fireball" fear-mongering lectures given to those who don't use the tightly price-controlled mainstream refrigerants will stop now that they're putting that R-1234yf stuff in new cars. I'd rather run propane/butane than that anyday, that is if I can't get my hands on R-12.
Offline TJ Hopland
« Reply #18 on: May 01, 2016, 09:01:40 AM »
Anyone know if the small appliances that used R12 had the lube in the refrigerant or were they more of a 4 stroke design where they had an oil sump?
StPaul/Mpls, MN USA
73 Eldo convert w/FiTech EFI
80 Eldo Diesel
90 CDV
Offline fishnjim
  • Name: J. Bozin
« Reply #19 on: May 01, 2016, 11:41:46 AM »
Refrigerant compressors usually run with the lubricant in the refrigerant loop, no sump.   It takes a test stand to test lubricants and you need different ones for different refrigerants.    So I don't recommend fooling around yourself.   You can lock up those vintage compressors.
Obviously, there's no magic refrigerant that works good, is non-flammable, and doesn't affect the atmosphere.   That's why they used 12 initially, best choice, but once the number of vehicles rose, it created the problem.   CO2 acts is a refrigerant but needs high pressure.
Now almost all the vehicle compressors, new and rebuilt, are coming out of China, so the quality isn't always up to par.  So that shoots the whole don't leak - trained technician concept in the rear.    If they used a good compressor and good seals, they'd last decades and not leak like your old refrigerators.   Which are hermetically sealed systems.   I had commercial systems run 24-7 for decades.
When you sell cars, eg: Volkswagon, and you put out something that the lawyers can take you to the cleaners on, you're a bit more cautious.   It makes no sense to value only the emission but not the mileage gains.
These pollutant reduction health impact "estimates" are BS.   They extrapolate data beyond known bounds.   It's the 55 vs 70 mph argument.   Yeah, you use less gas at 55 but you have to travel longer to get to your destination, so your burning gas longer.  When you take that into account, the difference is not so large, but they brain wash people with the govt hype.
