hood hinges for '74 ELDO convt
Started by Viator Trudeau, June 07, 2016, 11:07:56 PM
Viator Trudeau
Where can I but a pair of good or rebuilt hood hinges??
V.Trudeau
Carl Fielding
Scroll down to May 30 , and read postings under "Hood hinge on 1972 Eldorado lost a bolt". A rebuilder is referenced among the replies. Also some tips on removing and supporting the hood. Good luck ! - Carl
e-bay for used, or send in a core pair of hinges to SMS.
dochawk
Quote from: Carl Fielding on June 08, 2016, 12:26:44 AM
It's at http://forums.cadillaclasalleclub.org/index.php?topic=140962.msg334711#msg334711.
Sometimes SMS has a rebuilt pair in stock and will send them if you pay a fairly steep core charge so you don't have to have a hingeless car for a few weeks while they repair them.
Back when I did mine they mailed a hand written check back to you for the core charge.  I remember that because when I recently moved I found the check jammed in some other papers.
