'67 Deville Front lower spherical joint dust boots
Started by Julien Abrahams, June 14, 2016, 03:25:43 PM
Julien Abrahams
Hello all,
I'm looking for front lower sperical joint dust boots. Mine are torn. I've looked on OPG's  webpage and Rockauto's website, but up until now I have only found these boot including the spherical joint. I just need the boots. Where to order them?
Julien.
1954 Cadillac series 62
1969 Austin Healey Sprite
1979 Opel Kadett
John Bryan #21196
You can only replace the entire ball joint. There are no boot replacements available to my knowledge.
John Bryan #21196
DeVille68
I recommend http://rareparts.com/  - they have what you need in true Cadillac quality!
Julien Abrahams
Thanks for the replies. It would be a bit weird if only the entire ball joint could be replaced. In the shop manual it also states that it is possible to just change the boots.
1979 Opel Kadett
DeVille68
Quote from: Julien Abrahams on June 18, 2016, 03:15:41 AM
Yes from that side of view it would make sense. But if the boot is ripped there is a good change that debris made its way into the ball joint and will cause it to fail sooner or later. Plus if you change the boot you would probably do 80% of the job anyways, so that is probably why there is only a full ball joint assembly available.
wbdeford
If you find a source of boots, let us know.....I would like to replace the rotting rubber on my '58 without giving up my original ball joints.
1958 Sedan de Ville
Past:
1956 Fleetwood 75 Sedan
1957 Fleetwood 60 Special
1960 Coupe de Ville
1966 De Ville Convertible
1970 De Ville Convertible
1971 Eldorado Convertible
1979 Sedan de Ville
1980 Seville
