71 Eldo: Grease tie rod ends?
Started by wbdeford, June 14, 2016, 10:26:03 PM
wbdeford
Shop manual says this never needs to be done, but they probably weren't envisioning over 40 years of use.  Should I be adding grease?
1958 Sedan de Ville
Past:
1956 Fleetwood 75 Sedan
1957 Fleetwood 60 Special
1960 Coupe de Ville
1966 De Ville Convertible
1970 De Ville Convertible
1971 Eldorado Convertible
1979 Sedan de Ville
1980 Seville
If it has a grease fitting I would, just don't blow the rubber seal.
wbdeford
It has threaded plugs which could easily be replaced by fittings.
1958 Sedan de Ville
Past:
1960 Coupe de Ville
1979 Sedan de Ville
1980 Seville
My '72 has grease nipples in the tie rod ends, so someone must have put them there if they were plugged when new.
But checking the Shop Manual for '72, there is no mention whatsoever of any grease points that require periodic greasing.
PS.   Yes, I grease mine.
wbdeford
The manual also says it is a "special" grease....no idea what kind that is or if there are any compatibility issues with regular chassis grease.
1958 Sedan de Ville
Past:
1960 Coupe de Ville
1979 Sedan de Ville
1980 Seville
