Tips on removing 60 driveshaft ???
Started by speach, June 23, 2016, 08:20:57 PM
speach
I have the trans out and the driveshaft is unbolted from the carrier along with the center mount bolts removed. Manual says to pull out from the rear but Im having a time due to the center pieces hanging. I do not want to damage it so any proper advice or tricks would be much appreciated.
William
Current cars:
1986 Military Chevrolet Diesel G30 Box Van
1968 Conv DeVille
1989 Toyota SpaceCruiser
You cant take your car with you in the end so drive the dang thing.
WilliamTrausch
The only way to remove it is to support the front of the rear shaft upwards, to allow the centre bearing to clear the inner lip of the crossmember.
As you are pulling it out, you might have to reach forward, and lift the front yoke up and over the front of the crossmember.
