SMS IN OREGON IS A GOOD BET. The material should be a grey with a dark blue thread...it is NOT TAN as in earlier thru 1947 cars. The cardboard is also grey with a kind of mottled effect with grey vinyl binding. The material is on the floor of the trunk as a separate piece and the hump on each side is a separate piece as is the piece that goes to the rear of the seat above the trunl floor pan. The 4 body mounting bolts with thick flat washers (cad plated) go thru the material with material under the washer and bolt to be 100% correct. The trunk lining was installed in the body BEFORE the body was mounted to the frame.Herman
