1957 AC system
Started by mirrormatic, September 07, 2016, 02:50:12 PM
mirrormatic
are the 57 and 58 components the same?
would the AC in a 58 roadmaster be interchangeable?
charles marshall
wbdeford
1958 supplement says, "A larger compressor of welded construction is used, with the head welded to the body.  This eliminates the possibility of any service on the internal parts of the compressor in the field.  The clutch assembly, the coil and coil housing, and the oil seal may still be serviced as outlined in the 1957 Cadillac Shop Manual.  The new compressor is driven by one belt instead of two as used in 1957."
So, at least the compressors are different.
1958 Sedan de Ville
Past:
1956 Fleetwood 75 Sedan
1957 Fleetwood 60 Special
1960 Coupe de Ville
1966 De Ville Convertible
1970 De Ville Convertible
1971 Eldorado Convertible
1979 Sedan de Ville
1980 Seville
