Dimmer Switch With Guidematic, '68 Eldorado
Started by joeinbcs, September 29, 2016, 03:56:31 PM
joeinbcs
Damn...I can't find one of these anywhere...
Most of our cars have this option...what are y'all doing?
Will a regular dimmer switch work if you just leave the green wire off?
Thanks for any help!
Joe
Joe Northrop
9633 Whispering Ridge
College Station, TX  77845
joenorthrop@yahoo.com
979-324-6432
1967 Eldorado, Atlantis Blue Firemist (slick top), Blue leather.
James Landi
How about a temporary "work around" --- especially if the switch is not available.  A couple of "field relays" and 2 toggle switch (under dash mounted) could get you on the road. You'd also learn a great deal in the process, and you can use the car without putting a strain on the alternator, battery, and your nervous system.
Ralph Messina CLC 4937
Joe,
If you're looking for the three prong high beam foot switch, I bought one for my '66 about a year ago;
Auto-Tech Warehouse - CA
626-337-0605
Manuf: WEL; PN: UDS420   About $6.00
HTH,
Ralph
BTW, Are you the Joe N.  from the MKII Forum?
2018 GMC Yukon
joeinbcs
#3
The switch has three spade connectors on the top side and another spade connector on the bottom side.
Three spade connectors are available everywhere, the correct switch for cars with guidematic, nowhere.
Joe Northrop
979-324-6432
Joe,
I wrote that description from memory and should have said 4 spade. My car has Autronic Eye and Twilight Sentenal
2018 GMC Yukon
joeinbcs
Thanks, Ralph.
I tried a three spade switch, and It had no effect (depressing the switch had no effect, and my high beams stayed on).
I'm thinking the problem may be elsewhere. While snooping around, I managed to pull the spade connector off the electropnenumatic relay, so another thing to fix😡  And, yes, I had a Mark II for a while and was active on the Mark II Forum then.
Thanks, Joe
Joe Northrop
979-324-6432
Joe,
Your MKII was a great looking car. If you apply the same knowledge and talent to Cadillacs you'll be well rewarded and your neighbors will be jealous of a sweet ride.
2018 GMC Yukon
Glen
Those switches are out there.  I have a brand new one waiting to go in my 68 ELDO.  But for the life of me I cannot remember where I got it.
It should not be hard to test the switch.
The headlight switch is also available but you have to go to a Pontiac web site.  They used the same headlight switch with the vacuum valve.
Glen Houlton CLC #727
CLCMRC benefactor #104
joeinbcs
Quote from: Glen on September 30, 2016, 01:18:52 AM
Well, if you happen to find a source, please let me know...I'm still searching.
As for the headlight switch, yes, I bought a Pontiac switch for my last '68 Eldorado...if only I could remember where I bought it from....LOL.  But that car had neither Guidematic nor Twilight Sentinel.  I can't remember if this is an issue using the Pontiac issue...
Joe Northrop
979-324-6432
joeinbcs
I think this is what I bought for my previous '68 Eldorado, which had neither Guidematic nor Twilight Sentinel.  Not sure if it will work with this car that has both.
Joe Northrop
979-324-6432
joeinbcs
Quote from: Ralph Messina CLC 4937 on September 29, 2016, 04:31:35 PM
Joe,
626-337-0605
HTH,
Ralph
Ralph, Hope I don't get in trouble for posting a non-Cadillac, but here's my Mark II, now owned by an Austin billionaire...
Best, Joe
Joe Northrop
979-324-6432
Glen
#11
Quote from: joeinbcs on September 30, 2016, 07:46:52 AM
The light switch will work with or without the Guide-matic and/or Twilight Sentinel.  You do have to remove the resistors that mount between the dash and the switch and put them on the new switch.
russ austin
61-69 are the same.   I have good used guide matic dimmer switches, that have been tested.   Shoot me an email to;  russ85747@hotmail.com
R.Austin
